Hi. I have a wireless doorbell with Homebase 2. I can’t find a setting in the app to enable a motion alert from the doorbell on the Homebase. I do get ringing alerts. Just to be clear, I want the motion alert on the Homebase - alerts on app work fine. Hoe can I set that up?
Homebase 2 motion alert from wireless doorbell
Homebase only acts as a chime and alarms when triggered. Motion notifications only appear on your app.
Refer the community for more help: https://communitysecurity.eufylife.com/
Ok, that is clear. Thank you for the quick response.
