I want to make sure I understand how eufy cameras connect to the homebase 2. Based on my research, it looks like you connect homebase 2 via ethernet and to wifi. The ethernet connection is for internet access for the eufy app to work and the wifi is to communicate with the cameras. When you sync the homebase and camera they “find” each other via the wireless connection you setup on the homebase 2. The homebase 2 doesn’t setup a complete separate wireless network correct? Am I understanding the setup correctly?
Assuming I understand everything correctly above. I have a great wireless system already in my house using Unifi with great connectivity even outside, can you permanently disable the wifi repeater on the homebase 2?
My overall plan is to put the homebase 2 on my IOT network via ethernet and my IOT Wifi network to connect to the cameras. The homebase 2 Wifi repeater will be disabled. Basically my eufy camera setup will only use my IOT network without the homebase 2 or anything else adding an additional wifi signal or boosting my IOT wifi signal Anything I am missing? Thanks.
Jeremy
