Eufy, with 2020/1 being a year where people will be working from home, please make a home noise cancellation system.
People will be trying to hold work calls with the kids or dogs at home and want the background noise of other than their voice not picked up.
Make it so you place a few microphones in the corners of the room facing external noises you want blocked and that sound is removed.
Consider also/instead those microphones placed near noises to be removed to then not necessarily in the room cancel the noise but have those sounds not transmitted through a speakerphone near you.
I searched and found similar to my idea, example:
