Headphone life q20 won’t charge
Just bought Headphone life q20, pulled it out of the box, it won’t complete charging, led is solid red. First started charging on laptop, then wall. Changed the cable to a known working cable, same deal. Disappointed!
You tried 1 and 2 so for sure a warranty issue.
service@soundcore.com
Quote serial number and order details
-Try a different wall charger and cable to charge the earbuds at least 24 hours no matter the indicator is on or off
  • Make sure the wall charger and cable used can work properly before testing it
