While some of you may be thinking this is a rather silly question it has caused huge debates in a bunch of my classes. So which do you use grey or gray or does it depend on the situation of how you’re feeling
- grey
- gray
- depends on how I’m feeling
0 voters
One of my friends says the answer should be always gray unless looking for clothing then it’s grey to “get the good stuff”
