Great unit bad feet Anker SoundCore Pro+
Great unit bad feet
June 13, 2019
Verified Purchase
Great sound, Great Bluetooth Connection but the rubber feet have all fallen off so it will rock itself off a surface possibly damaging the unit. It also vibrates interfering with the great sound. The cannot send you more feet you have to return the whole unit.
Is there a way to attach the feet better, perhaps with a stronger glue/adhesive than what is already used? From what I’ve seen before, if this is a widespread occurrence than Anker will get right to the bottom of it.
Screwing them into the body (with the correct screws and with the correct body) would probably fix this issue. But that would need to be taken into consideration during the design process.
