Hello there
I recently received a pair of Liberty 2 Pro’s- really happy with them generally, however I started using them for running and have had an issue with the GPS not functioning properly on my Garmin watch.
I have a Garmin Fenix 3, which worked flawlessly in my local area before using with the headphones. I start the watch before running and it finds GPS whilst stationary, but as soon as I start moving it loses connection. I looked on the Garmin site, they suggest the bluetooth can interfere with GPS signals, so they suggest trying the watch on the other wrist, which I did but this doesn’t appear to have made a difference.
Does anyone else have similar problems or any suggestions to fix the issue? I’m not sure if I should be posting on this forum or the Garmin forum to find an answer, so I’ll probably try both!
Thanks
Ed
