Anyone find the volume of speaker in the floodlight very low? When trying to communicate it’s almost inaudible.
Floodlight volume
What speaker are you talking about?
Give us some more specifications, please.
Otherwise no answer will be possible, Sorry!
I’m referring to the speaker inside the floodlight that is used to communicate using the “hold and speak” button.
You can adjust the volume via the app, its also dependent of The volume of the device being used as well
