Fixes some language issues for both and adds full EQ control to the Flare+. The app update also adds support for Model Zero!
Firmware update for Flare and Flare+ available
Looking forward to the full EQ.
I have updated the SoundCore iOS app to the latest version 1.2.0. From there I am trying to update the firmware to 2.70 for my Flare+. The firmware downloads to my phone (1.47MB) but for some reason fails to install on the Flare+. It says installing, displays 0% on the gauge, sits there for 10s then it displays an error message: “An error occured. Please try again later.”
Did anyone encounter the same problem? Any ideas, suggestions, workarounds? @AnkerOfficial ?
Thanks!
I’m using the Android app and 2 original Flares and didn’t have an issue, in case that helps Anker with troubleshooting.
Hope someone comes along soon with answers about iOS app and the Flare+!
Thanks for posting!!
Thanks @RuhRoh, I just succeeded installing the firmware using the Android app (had an old Android device that I managed to use).
The interesting thing happening now is that the iOS app is not able to connect to my Flare +
I’m using the latest iPhone and have the same error mesage.
Are you guys all using the same iOS? Is there an upgrade that maybe some iPhones haven’t installed yet?
My Flares updated yesterday. They were connected to an iPhone 8 with iOS12 - all my apps were updated as well, so I’m assuming I was using the latest version of the Soundcore app. The update ran without issues and was quite fast - much, much faster than the update on my wife’s Bose. I couldn’t confirm the update was sent to both units - I assumed it was and I was too lazy yesterday to connect each unit individually to check…
Anyway, after the update the Flares reconnected automatically. No hassle. I can’t say I noticed any differences in using them, though - I just resumed the song I was playing before the update started…
Thanks, wonder if the folks having trouble are on iOS 11 or if the issue is with updating the Flare+ with 1OS 11 and 12 but not Flare.
Ah, yes, I should have been specific: I updated “non-plus” Flares… And I was playing music when the update started, I paused when I saw the warning on top.
Surprised support for Model Zero was added before Model Zero+ as not only did we heard that Zero+ was coming first back in April, but it also passed through the FCC first.
Doesn’t make sense to me to release the premium model first.
I was able to update using my iPad, using my iPhone Xs Max wouldn’t work, both are using OS 12.
Kinda make’s sense (Apple does it often )…release the more expensive model first for those that really want one & it’s features followed by a reduced cost model (minus some features) for the wider market…
I have iphone X, IOS 12, Flare speakers (2)
Current version 2.30
Firmware update is 2.47, size 1.57mb
firmware downloads, fails to install (error occurred)
@AnkerOfficial, want to get in here about the problems iOS users are having with the new Soundcore app update, particularly around the Flare +? Though it appears iOS users are also having issue with the Flare?
I have the flare + updated firmware with iOS 11 without problems without updating the Soundcore app. Now I can’t connect through the app. On Android it works.
I am having issues updating both my Flare and Flare+. Running iOS 12 with the latest Soundcore app.
I’m also seeing the error when trying to update firmware. My setup is IOS 12 on iPhone Xs and Flare (non-plus) speaker. Soundcore app was newly loaded.
