It keeps telling me no hdmi signal. I’ve tested the fire stick with another projector and it’s in perfect working order. I feel like the shape of the fire stick may be obstructed from connecting fully. Has anyone else had this problem?
Fire stick not working with prizm 2
Have you tried with the fire sticks included HDMI extender?
The cable extender shouldn’t be necessary but it would be a good thing to check.
I think @Jesse_Hernandez1 is on to something here. When I first received my firestick I plugged it in and had the same problem. Then I realized there wasn’t a full connection between the firestick and the tv due to the shape of both. I added the hdmi extender and it worked flawlessly.
I tried the extender and and it works. Thanks for all the help.
Glad you got it working, it sucks that you have to use the wire extender but it’s good to know the solution thanks for reporting back.
this worked for me too. Thanks for the solution I use the hdmi extender and it worked too.
