Good day!
I am interested in the Anker PowerHouse 767. My question is: Is it possible to connect a car battery with 12V directly to the XT-60 socket and thus increase the capacity of the Powerstation? For example with a cable like the one in the picture attached.
In the FAQ is says:
Any 11-60V solar panel with an XT-60 socket can charge the 767 Power Station. If you use an 11-32V solar panel, the current supports a maximum of 10A. If you use a 32-60V solar panel, the current supports a maximum of 20A. We recommend using Anker 531 solar panels (200W) for best compatibility.
So regarding the input voltage it should be ok, i guess?
The manual states that it is possible to connect the powerstation to the car via a car charging cable. As far as I know the automobile auxiliary power outlet is wired directly to the battery in most cars (with a fuse in between). So connecting a car battery via the cable above should be the same as using the car charging cable, right?
Any thoughts and tips on this topic are welcome!
Kind regards
