[EXPIRED] USA Anker USB-C HDMI cable , Magnetic Cable holder
Edit: codes expired.
Use the codes above at checkout, after adding to basket from links below
https://www.amazon.com/dp/B08DLK2FD9
https://www.amazon.com/dp/B08BLLNV44
Ooooh, the magnetic cable holder @professor
Do you think we will see that in the UK?
Yes, as these are not country specific products, it’s just a shipping warehouse stock dimension, so I’d say no more than weeks.
Wish I had an use for the magnetic cable holder :grimacing:
i saw the cable holder, I like that its magnetic and separate parts. All the others I’ve seen are one piece you stick to your desk
Some more good finds @professor . Thanks for the share :+1:
Lets see then @professor :+1:t2:
I tried to use the code for the cable holder, but I get is this message: “The promotional code you entered is not valid.”
They’re time and quantity limited, too late.
Edited to say expired.
A post was merged into an existing topic: Spam Links / Accounts - ongoing
