At first: welcome to the world of euf cam @ndalby !
I promise you … you will see the watermark much faster as you want too
At first: Tabing on “Check for latest firmware” for the homebase and/or cams may result in something like: “Firmware is up to date”. But as we are in the world of eufy, thats means just NOTHING! Probably its just a lie
… In most cases there IS a newer firmware, your homebase and/or cams just havn’t started to download it.
Then you just need to have patience and wait. Once in a while you will get an updated notice.
Be also sure that you have installed the latest app version. My google play sometimes informes me also each days and much too late after/that a new version is available in the store.
Don’t know if the US and EU versions are equal, but for orientation:
My current versions, and i hope they are the most latest:
Homebase: 1.1.0.8 (updated on 2019-07-19)
eufy cams: 1.9.2 (updated on 2019-07-19)
App (android): 1.3.4_280(EU)
While using several original eufy cams and also eufy cams E, be assured that eufy cam E will also have the annoying pixelwasting watermark, see screenshot from one of my eufy cam E’s (old boiling room):
Be also assured that this probably will never happen
eufy even needs in emergencie cases or really hardcore bugs several weeks(!) to “hotfix” it!
They also said that it will need up to three months(!) to see if the will remove it or make it optional.
To be honest, i guess “hotfix” and its meaning does not even exist in eufy’s vocabulary
