I currently have Eufycam E however I need additional cameras.
I have the option to buy the original Eufycam, but not sure if it is worth swapping?
I can’t see any reason to have more than one base unit, therefore I would use one or the other. Why do some people have more??
A bit concerned that the original one will stop getting updates if it is not actively being made now.
Is the original a lot better?
The cameras are much larger, so that is a negative. Eufycam E cameras are nice and compact.
Just not sure if effectively swapping the base unit is worth it. Or do I just buy new Eufycam E cameras?
Opinions welcome…
