Hello,
I have purchased the 4 eufyCam (not E) and pretty happy with those so far and need to add another 4.
What I discovered is that the base station doesn’t need to connect to Ethernet cable and can be connected via WiFi.
This should be great as it makes it easier to move the base around to get a better signal for the cameras.
So what I was thinking to do is buying another set of 4 (with a 2nd base station) which should allow me arranging the cameras in optimal configuration.
So my plan is to:
- base 1 - plugged into ethernet
- base 2 - opposite side of the house, connected using WiFi but closer to the other set of cameras
- 4 + 4 cameras arranged as close as possible to their base stations
Are there any downsides to this configuration (other than obvious WiFi vs Ethernet) from the app perspective?
Can a camera from one base station trigger an alarm on all bases?
Are there any gotchas from the iOS app perspective (multiple users)?
Has anyone done similar and would you recommend for/against such setup?
Thanks in advance
