EufyCam Homebase 2 2.1.2.8h Update, Cams started to push for every motion instead of Human detection only
Does anybody else have the same problem?
After any update its a good idea to go in and check and reset things, updates fix stuff but also break or reset things and they have to be set back
I’ve tried turning off and setting the motion detection to human only, but no beuno.
This is the first time it has happened to me since I bought the system last year in December.
I have also experienced this. It was working really well (apart from at night, where car headlights would set it off), and now it picks up all cars driving in and out of my driveway. Is there a fix on the way please Eufy!!!
Well I called eufy last week and they said they are aware of the issue and are pushing new firmwares out…
Fingers crossed they get this fixed asap, because it is bloody annoying. Thanks for responding!! :slight_smile:
