Hello everybody,
how do you set up a Eufycam E stream in Kodi or Synology? I just have the problem that after activating the stream in the app, the stream is activated once, but if you try to call the stream again, it is no longer available.
In Kodi I have set up a .strm file for this case and call this file. A video with the address rtsp://ip/stream should be called. The first time it works, the second time (even after restarting Kodi) it doesn’t. Same behavior with Synology NAS and VLC.
I have to disable the RTSP feature in the app an reactivate it to get a one-time-call stream again… Unfortunately this is not useful. Do you have any tips on how to do it right? Is it possible at all?
rene
