I bought the EufyCam E this week and set it up without any problems. Over my home wifi connection I can see all the camera streams and recorded events but if I change to cellular connection or at my works wifi conenction the app says my homebase is offline.
Also if I login to the web portal it says the homebase is offline. I do get push notifications when motion is detected so the system is functioning but I want to see the captured video whem I’m not at home.
Did I miss something in the installation or do I have to open some ports on my firewall?
Does anyone else have this problem?
