Hi
I have purchased an Eufycam E and am looking to set it up with platerecognizer.com to scan licence plates in my driveway. I am planning to use node-red. The plate scanner just need a still picture sent upon detection. Is this possible?
Hi
As the site relies on uploading an image (which you could export through the EufySecurity app) I can’t see why you would not be able to accomplish what you are after.
If you are wanting to automate this, I don’t believe that would be possible with the EufyCam system. I would suggest you reach out to support@eufylife.com to confirm.
Thank you for the reply. Do you know if EufyCam E works with IFTTT?
If you use the search button, upper-right
https://community.anker.com/search?q=IFTTT%20order%3Alatest
It has been asked and discussed many times, pick your thread to reply there.
