Eufycam - Audio Problems/Optimization
Is there any way of optimizing the audio, I’m finding it very hard to hear/understand voices, as it is mixed with a lot of wind noise, even on a relatively calm day.
Also, is there an good app that I can play the video through that will take out the wind noise and clean up voices
Can you post a video example of this? We can see, on our end if the amount is normal or not.
As a side note, you’ll find that most microphones will pick up wind noise, especially if there is a lot of it.
Or you can try another way, you can turn on the live view, then you will find a speaker underneath, you could turn off the speaker and see if it solved your problem.
Can i send it to you rather than post the video?
You could post video link in this thread or sent to my private message. Also, Have you try the way which I mentioned?
I have the speaker turned off on Live View anyway, I was a bit scared that if i turned it on people would hear me out of my camera, is that right or only if you push the microphone
This is only if you push the microphone!
What is your private message so I can send the video
Click on the name @AnkerSupport and you will see the message box at the top. Click that to send them a message
It would’ve been nice if you’d posted fixes, since the problem still persists in 2024. Unless the person is a foot away from the camera, the wind interferes with the clarity of the audio.
Also on 2025 audio is crap sound muffled just got the eufy cam 3 thinking of returning it
