Eufy Wired Doorbell live view
I just purchased and installed eufy wired doorbell… it is working great (except keeps failing on firmware update for some reason, will deal with that later). My only other problem is I want to be able to have a live view up on my PC. I have a dedicated screen on my wall that is used for live view of my front door cam (now the eufy, was an ip cam prior). I chose this doorbell camera because it had the option of logging into the website and viewing live stream… and that works but only for like 5 mins or so at a time and then stops and you have to restart it up again. What is the solution to keep the live view up all the time on a pc monitor?
thanks.
