Eufy Spaceview audio threshold/VOX mode?
Hi, I’m interested in the eufy Spaceview but have a question/concern about the audio functionality.
Aside from questions about support for multiple cameras, the main complaint about the spaceview in reviews is the way the audio monitoring functions. My understanding is that it currently supports two modes (please correct me if I’m wrong):
  1. Audio is always on, so you can turn the volume up or down but there’s no way to set a noise gate threshold to avoid hearing low volume noises/white noise machines/etc on the monitor, or
  2. Turn audio monitoring off but set an alarm when a threshold is exceeded. This option is mostly fine but the beeping alarm is apparently very loud and jarring.
Most audio monitors have the ability to set an audio noise gate threshold at mulitple levels, so that small or constant noises aren’t heard on the montior. When that theshold is exceeded, the audio monitoring should simply turn on, instead of a loud alarm.
@AnkerOfficial Is this or a similar feature being considered by the product team? Seems like something that could be released in a software update, and it would address one of the only major complaints about the Spaceview. Thanks.
