Love the scale,but cannot find a way to delete an entry in the history section in the app. I’ve stepped on it multiple times just learning how it works. Also have stepped on scale and it only recorded weight?
Eufy Smart Scale C1
As @ndalby says just swipe left and press the ‘X’ on the readings you do not want. This should delete your entry. Also you need to step on the scale for 20 seconds or so. You will see some dashes on the screen go up and down on the screen and once they are done you can step off. This should record all of the other information.
Thanks, easy when you know what to do, missed reading this in the instructions.
