Eufy Security, Wi-Fi Video Doorbell with 2K HD, 2-way audio Deal for $119.99
eufy Security, Wi-Fi Video Doorbell with 2K HD, 2-way audio, No Monthly Fees (Requires Existing Doorbell Wires, 16-24 VAC, 30 VA or above)
Deal for $119.99 with $40 off Amazon coupon
Buy here
Key Features
video door bell
Storage You Can Trust
Military-Grade AES 256-Bit data encryption ensures your footage is kept private on transmission and storage.
video door bell
A Clear View
HDR imaging ensures high clarity for backlit or low-light scenarios, providing a clear image day and night.
003
See More
eufy Security Video Doorbell uses a 4:3 aspect ratio to offer a bigger viewable area from top to bottom.
004
Who’s there?
Receive facial snapshot notifications so that you can quickly check who is at the door.
Key Features
video door bell
Smart Detection Zones
Activity Zone allows you to customize the areas in which the camera will detect motion. Set the Activity Zone to suit your home so you only receive the alerts you care about.
video door bell
See the Whole Picture
View 3 seconds of footage prior to the initial alert. Gain a clearer picture of what happened and increase the likelihood of criminal identification.
video door bell
Interaction Made Easy
Record and set up to 3 instant responses. When you are notified of activity simply select one of you pre-recorded responses to interact and give instructions.
video door bell
“Hey Alexa, show me my front door”
Connect your Doorbell to Google Voice Assistant or Amazon Alexa and check in anytime on what’s happening outside your home.
Description
From eufy, the home security brand where privacy comes first.
• Comprehensive Safety Solutions for Your Home
• Created by the same team as Anker—renowned for exceptional quality and innovation
Protects You, Your Family, and Your Privacy
Every eufy Security product is engineered to ensure your security data is kept private. Have peace of mind that you will have a secure record of everything that happens around your home.
See Who’s There Before the Ring
Get instant alerts for anyone who approaches, even if they don’t press the doorbell. Interact with visitors by talking in real-time or via pre-set responses.
“Alexa, show me my front door”
Connect your Doorbell to Alexa or Google Assistant and check-in anytime on what’s happening outside your home.
Record and set up to 3 instant responses. When you are notified of activity, simply select one of your pre-recorded responses for a simple way to interact and give instructions.
Note
The video doorbell is powered by the original doorbell wires. Users need to modify their original chime per instruction or upgrade the doorbell transformer if the original doesn’t deliver sufficient power. Users may need to hire an electrician at their own cost if they are not comfortable with the installation process.
What’s included: Video Doorbell 2K (Wired), Screw Hole Positioning-Card, Mounting Bracket, 15° Wedge, Jumper for Existing Chime, Extension Wires, Screw Packs, Doorbell Detaching Pin, Electronic Doorbell Chime, Doorbell Power Pin, Quick Start Guide.
Features & details
  • A Crystal-Clear 2K Image: High Definition 2560 x 1920 resolution, combined with our advanced HDR and Distortion Correction, ensures video is recorded in 2x the quality.
  • No Hidden Costs: Designed to protect your home as well as your wallet, eufy Security products are one-time purchases that combine security with convenience.
  • Respond in Real-Time: Speak directly to anyone who approaches your front door via two-way audio. Tell your friends to come round the back or that you have just run out to get some milk.
  • The Alerts Which Matter: With AI technology and our sophisticated algorithm, the camera intelligently detects body shape and face pattern. Ensuring you are only alerted when a human, and not a stray cat, is at the door.
  • Free electronic chime included: Supports 8 fun and holiday themed ringtones and adjustable volume level. Note: Existing chimes will not work with eufy Security Video Doorbell.
Amazing deal :clap:
Awesome deal!
If you see him in front of the door you should ask the community what to do! :joy:
Lol
Great deal but still looking for $99 deal :roll_eyes:
