Eufy robovac noise problem
Eufy too noisy - making loud clunky sound as it operates
  1. Power OFF and Clean brushes and tap the wheels to see whether they are stuck, and if necessary, remove any hair and debris from them.
  2. Remove the rolling brush and brush guard and run RoboVac to see if the noise continues.
  3. Shake/tap the bumper and wheels to see whether they are stuck, and if necessary, remove any hair and debris from them.
  4. Power ON RoboVac by turning the power switch On.
If the noise does not disappear when you remove accessories, please contact us at support@eufylife.com for more assistance.
