eufy robovac filter types
I’m really confused by the different filter types and they also seem to have changed.
I have a 30c Max, which has a “pre-filter” that “covers” the regular filter. So cleaning it is really easy because the pre-filter’s surface is flat.
I also have a 30c, which doesn’t have the pre-filter. Cleaning it can be tough because of all the grooves in the filter.
I’m considering upgrading the 30c to a G30, but it seems like the G30 also doesn’t have the pre-filter?
And also during my research, it seems like the 30c now has a pre-filter?
So my questions:
Does the G30 have the pre-filter? i.e. when you clean the filter, do you just wipe the flat pre-filter surface, or do you have to deal with the nooks and crannies of the filter?
Can you replace the non-pre-filter bins with a bin that uses a pre-filter? Are the bins compatible with all Eufy robovac models?
