Eufy Robovac 11S Max Deal for $189.99
Product description
3
3-Point Cleaning System
Three brushes and strong suction power effectively loosen, extract, and vacuum dirt to give a superior clean.
4
Smart Return
Never worry about running out of juice.
RoboVac automatically returns to HomeBase when battery is low.
5
Versatile Cleaning Modes
A cleaning mode for every scenario. Ensure an effortless, thorough cleaning while you relax.
6
Disturbs Dust Not People
Advanced brushless motor significantly reduces vacuuming noise.
7
Drop-Sensing Technology
RoboVac uses advanced sensors which detect drops to avoid falling down stairs and off of ledges.
8
Treads Lightly
Anti-collision sensors ensure RoboVac doesn’t bump into objects around the house.
9
Knows Your Home
With over 10 built-in infrared sensors Robovac is constantly aware of its surroundings.
10
Non-Stop Cleaning
Large wheels roll over carpets and climb over door ledges to get to the mess.
Model:T2126
RoboVac 11S MAX
The Super-Slim and Powerful RoboVac
Eliminate Vacuuming Chores
RoboVac takes on dust-busting around your home so you don’t have to. Multiple cleaning modes and auto-clean scheduling ensure an effortless, thorough clean while you relax.
Lean, Mean, Cleaning Machine
2000Pa of suction power ensures your home is clear of dirt, dust, and crumbs. RoboVac may be super-slim, but it’s packed with a 3-point cleaning system consisting of a suction inlet, roll-brush, and side-brush which deliver meticulous cleaning.
Cleans While You Relax
Refined from the inside out to provide quiet vacuuming with zero hassle, RoboVac cleans with the equivalent volume of a microwave, and is only 2.85” tall to clean under low-hanging furniture with ease.
More Dust, Less Fuss
A large 0.6L dustbin allows RoboVac to pick up more dirt and dust to take full advantage of 100 minutes** of continuous cleaning.
Premium Components
The anti-scratch tempered glass cover provides a sleek look and superior protection for RoboVac, while the unibody filter achieves a better clean for your home.
For Optimal Use:
  • Use on low- to medium-pile carpets, tile, laminated, and hardwood floors. Not suitable for high-pile carpet or very dark-colored floors.
  • Move cables out of the way to avoid tangling. 5 cable ties are provided in the package to help you better organize wires and power cords.
Note:
*Compared to previous eufy RoboVac models.
**Standard suction mode (hardwood floors) provides approx. 100 mins of cleaning. BoostIQ mode (carpeting) provides approx. 60 mins of cleaning.
Max suction mode on medium-pile carpets provides approx. 40 mins of cleaning.
Nice post on the Vacuum.
Great vacuum and great deal :+1:
Great price!!
Cracking price for a Willy :muscle:t2::tongue:
