When I select the continuous playback time from the Eufy application, the camera clock shows the recording 1 hour ahead. I also adjusted the Homebase time settings. Live camera and homebase times are correct. What’s problem?
Eufy playback time problem
Hi
Had this issue been fixed for you? I am having the same issue tried changing the time zone and following eufy useless suggestions but still no luck
In think there is an app issue. I have 3 cameras and only the e330 pro is causing this issue
