I can’t figure out how to connect my Eufy indoor security cam with the homebase 2. Do I select nas or a its own wifi network? Is that not a possibility? If not, It should be.
Eufy Indoor Cam compatible with homebase 2?
Good question. The instructions are lacking. I installed mine using it’s own micro SD card. Regardless, it would have been nice to have it record to the homebase. It does work with it but it was unclear how to make it record to the homebase.
