Eufy Homebase2 does not connect thru WIFI
Connect the HomeBase2 thru ethernet and finish all setup. Then try to connect it via WIFI to the same router but the SSID is not showing in the list. I have 2x different WIFI routers (both on 2.4Ghz): 1) Nokia 5G Fastmile Gateway and 2) TP Link Extender. Very different brands still not working. I start thinking if my Homebase2 is faulty. Any solution?
