I have 2 Eufy Homebase 2’s. They are both on static IP’s. I have 6 cameras paired between each of the HB2’s, 3 to one HB2 and 3 to the other HB2.
When I turn on NAS (RTSP) Stream I get the same IP address for each of the 3 cameras. Is this normal? How do I differentiate each camera so that I can view them through a RTSP viewer?
I also have 3 Eufy Indoor Cameras and when I set up static IP’s for each of them I have no issues, they are all on separate IP addresses. I realize this is because they don’t run through a base station.
I am using a RTSP viewer app on Apple TV that sees all of the Eufy Indoor cameras with no issue, and it will see one of the 3 cameras through both of the HB2’s that all share the same IP address. (This is after I turn off the RTSP Stream for 2 of the 3.)
Any help is greatly appreciated.
Thank you.
