Eufy floodlight camera is flashing for days
My Eufy Floodlight Camera now always flashes when the light is supposed to be turned off. Is there a fix for this?
Ask there as well :
Thanks for the info. I am looking for the same issue. Keep suggesting such info.
AlaskasWorld
It is @Chiquinho to the rescue.
Hi @Andrew85
Were you able to find a solution to this in the end? We’re having the same issue with a camera that’s only been installed for about 3 months.
Thank you.
Got the same issue with a camera/floodlight I installed last month. Worked good first weeks and later nothing. Deconnect seemed to work but onces it turned lights on via the camera (not the manual test) I gave the same issue. Created a topic on Eufy forum: https://community.security.eufy.com/t/eufy-floodlights-permanent-on-or-flickering/3899309
