First, let me start off with saying that I am a network administrator in my day job. I have searched the forum, Google, etc. with no luck.
What are the required firewall ports and IP addresses needed from the remote viewing subnet to open to the outside for viewing the Eufy cameras when NOT on the same subnet as the HomeBase? My HomeBase is located on my IoT very unrestricted subnet. I can view them when on a cellular network or on a very unrestricted wide-opened firewall.
I see that tcp:10280, udp:32100, udp:32700 are needed but I will NOT open a bunch or a range of upper tcp or udp ports to * (ANY IP) on my secure/private subnets or on my employer’s firewalls. tcp:80 and tcp:443 already enabled by default. I also see when these few ports are opened on my employer’s firewall, the app tries to connect to the internal IP address of the homebase at my house (smartphone = 10.10.90.204:xxxx --> (homebase) 172.20.4.61:xxxx), which of course will never work.
I should NOT have to open firewall ports to be able to remotely view the cameras when not on the same subnet as the HomeBase. VPNs will not work either as it is on a different subnet as the HomeBase.
Thank you,
Michael
