Eufy E340 doorbell lights control
I’m considering buying the Eufy E340 doorbell but wonder if you can disable the top/bottom illumination? My door is very close to the street so I think the lights could be triggered constantly or attract vandalism
Thanks
Du kan deaktivere det ved at slå night vision fra. Knappen lys kan også slås fra
You can adjust the light settings in the Eufy Security App
