I have the Eufycam e two cam system, if I buy the add on battery doorbell will it be compatible with the homebase that came with the cam system or do I need a different home base?
Eufy e two cam system compatability with add on cam
Unfortunately it will not be, the battery operated doorbell has its own internal memory and is not compatible with the homebase
