EUFY doorbell Motion Detection is stuck on 30 minutes
Hi,
I recently purchased and install the battery operated Eufy doorbell. Picture and video quality is good. However, when I try to disable the motion detection snooze, it doesn’t allow me to save that setting. Thus its always stuck on 30 minutes.
Can someone please advice on how to fix this? I’ve look into other security settings but nothing is working.
Thanks,
Andrew
Can also add that I’m not receiving any push notifications when doorbell is activated or when motion detected (and video is recorded). I’m using iphone X. I’ve checked all settings and software is updated. Please help.
Thanks.
Hi @AndrewYHC,
Thanks for letting us know the issue.
Please try resetting it first. If the issue persists, please email us at support@eufylife.com with your account details so we can address the problem for you.
Thank you very much for your patience and understanding.
The Anker Community Team
I’m having the same problem- using iPhone 8 with iOS 13+. I will try the resetting but I may be reaching out as well
Send support an email
