Hello,
I just purchased the Eufy Video Doorbell 2k and am excited to get it installed. I started to try to install it, but noted the wires on my chime are labeled differently than in the instructions. My Broan chime wiring is labeled 1, 2, and 3 rather than front, trans and back as in the instructions. Can anyone translate these for me? Support isn’t open (of course) and I couldn’t find any info in my search. See pic of my wiring. Thanks,
Pat
Eufy chime bypass
Can you provide a model number of the chime and a picture of the cover?
Yea, that looks correct.
I would say there is a small chance your transformer may not be big enough. It looks like your model chime has battery terminals which would be in place of a transformer. Seeing as there are no batteries, and isn’t wired for it, I assume the doorbell works which means there is a transformer installed.
That, and 42 is the center of the universe
42 is the Answer to the Ultimate Question of Life, the Universe, and Everything
@The_Bearded_Tech_Guy Thanks for stepping in to help!
@Pat9 Let us know if you have resolved your question or not.
