I made a post the other day but I can’t find it to respond an update to it. Anyways, I’m on Camera number 2 in the past 6 months that stopped working. Camera #1 was an original Eufy that the batteries stopped working. I changed out the batteries and the camera has been working fine since. Now here I am on camera #2 which is a Eufy 2 Pro…This time the camera only works when its plugged into a USB port. The batteries are holding a charge fine but when the camera is disconnected from a USB port the camera shuts down.
I have since opened up the camera which is much easier than the Eufy 1 to find that there is water inside of the camera. There are terminals corroded and rust forming on the inside of the case. Apparently this camera is not as water tight as the Eufy 1. I even had the protective silicon cover on the camera which I told Eufy before it does not help at all…
Note: This camera was mounted to a tree with the silicone cover and a solar panel plugged in to keep it charged.
Note 2: I think my original post was deleted
