Hello, after updating to APP android 1.3.0 228_eu I activated, in the security options, the mode of deactivation of the movement on all cameras.
Now I have to re-enable day mode, but the andriod app continues to shut down.
I have no possibility to reactivate notifications and registration.
I ask for urgent help. Thank you
[EUFY CAM BUG REPORT] Security Mode HELP HELP
Solved. I have unistalled app 1.3.0.228 eu and installed previous version. Bye
Ja often a downgrade after an upgrade is helpful.
Surprised you can do that?? at least not in the IOS app store, or I may be missing some thingsā¦
Anyways, glad to know that your problem is solved.
