Eufy BoostIQ RoboVac 30C MAX, Wi-Fi, Super-Thin Deal for $269.99 (with $50 off Amazon Coupon)
  • All-New RoboVac: Re-engineered to boast our strongest ever suction power (2000Pa Max) while maintaining quiet operation and a super-slim design (2. 85”).
  • Wi-Fi Convenience: The EufyHome app, Alexa and the Google Assistant voice control-services let you accomplish your vacuuming needs with zero effort from you.
  • BoostIQ Technology: Automatically increases suction power within 1. 5 seconds when extra vacuuming strength is needed—so you get the best clean.
  • Set Boundary Strips: RoboVac uses specialized dual-Hall Sensors to detect the Boundary Strips you set, ensuring it only cleans the areas required.
  • What You Get: RoboVac 30C MAX, 13. 2 ft. Boundary Strips, remote control (2 AAA batteries included), charging base, AC power adapter, cleaning tool, extra set of high-performance filters, 4 side brushes, 5 cable ties, welcome guide, and our worry-free 12-month .
  • Power Source Type: Corded Electric
Product Description
T213011102 T213011103 T213011104 T213011105
#### Knows Your Home
With over 10 built-in infrared sensors and Drop-Sensing Technology, Robovac is constantly aware of its surroundings.|#### Routine Cleaning
Customize a cleaning schedule that suits you. Simply set RoboVac to clean any time, any day, all via your phone. Select multiple days and ensure your floors are always spotless.|#### Remote Control
Control RoboVac’s exact movements via the app so you never miss a speck!|#### Just Follow the Sound
If RoboVac gets stuck or is playing hide-and-seek, just tap the Find My Robot button in the EufyHome app to find it without effort.|
T213011106 T213011107 T213011108 T213011109
#### Minimum Hassle, Maximum Convenience
The redesigned Unibody Filter increases efficiency and lasts longer which means less fuss for you.|#### Holds More
The larger, upgraded inlet allows RoboVac to handle more dust, fluff and hair with ease. The increased capacity means less maintenance for you.|#### Disturbs Dust Not People
Advanced brushless motor significantly reduces vacuuming noise.|#### 3-Point Cleaning System
Three brushes and strong suction power effectively loosen, extract, and vacuum dirt to give a superior clean.|
Model:T2130
RoboVac 30C Max
Connected, Powerful and Controlled
Complete Control
Alexa and the Google Assistant connectivity - Simply ask and RoboVac will take care of the cleaning while you sit back and relax.
Use the app to set RoboVac to clean, regardless of where you are!
Eliminate Vacuuming Chores
RoboVac takes on dust-busting around your home so you don’t have to. Multiple cleaning modes and auto-clean scheduling ensure an effortless, thorough clean while you relax.
Lean, Mean, Cleaning Machine
2000Pa of suction power ensures your home is clear of dirt, dust, and crumbs. RoboVac may be super-slim, but it’s packed with a 3-point cleaning system consisting of a suction inlet, rolling-brush, and side-brush to deliver meticulous cleaning.
Knows Where to Clean
There are certain areas within your home, such as your kid’s play area or your pet’s bed that you want RoboVac to avoid. Set Boundary Strips to create no-go-zones.
Cleans While You Relax
Refined from the inside out to provide quiet vacuuming with zero hassle. RoboVac cleans with the equivalent volume of a microwave and is only 2.85” tall.
More Dust, Less Fuss
A large 0.6L dustbin allows RoboVac to pick up more dirt and dust to make the most of 100 minutes** of continuous cleaning.
Premium Components
The anti-scratch tempered glass cover provides a sleek look and superior protection for RoboVac, while the unibody filter achieves a better clean for your home.
For Optimal Use:
  • Use on low- to medium-pile carpets, tile, laminated, and hardwood floors. Not suitable for high-pile carpet or very dark-colored floors.
  • Move cables out of the way or use the cable ties provided to avoid tangling.
Note:
**Standard suction mode (hardwood floors) approx. 100 mins of cleaning. BoostIQ mode (carpeting) approx. 60 mins of cleaning. Max suction mode on medium-pile carpets approx. 40 mins of cleaning.
Make sure you are using a 2.4GHz router or a dual-band router that is configured to support a 2.4GHz frequency band. RoboVac doesn’t support 5GHz frequency band.
The use of Bounce Navigation means that RoboVac will follow a random path when cleaning. This method is still proven to cover an entire room over time.
Buy here
Great Discount !!
awesome discount for a great vacuum cleaner
