Both the floodlight and the doorbell have been added to the app!
@AnkerSupport is there any eta you can give us for when you’ll be releasing info on these?
Probably never if it outside USA
I hope this thing will have Google Assistant support so I can display live feed on any Google Home with a screen or Chromecast…
There is already support for the cameras on the home hub so I’m sure will be support for the doorbell
Unless the doorbell is going through the Eufy Homebase (I hope not) its going to be a different source so I wouldn’t assume anything just yet with that.
I for one hope it does go through the homebase. This way the homebase can act as the doorbell sound. Considering everything in the eufy security app requires the use of the homebase (so far) I wouldn’t see this as too far of a stretch.
I currently have a nest hello and am looking forward to this as it should be able to take advantage of the homebase local storage.
That being said, since eufy is soon launching a cloud based service it’s possible it can run separately on the cloud + phone notifications or optionally with the homebase if you have one. If this isn’t homebase compatible at all I personally have no use for it.
Hopefully we’ll get some answers soon!
IEEE802.11 B/G/N
I too hope they all have inter connectivity, but I doubt it. It may be a stand alone device, good thing is it uses the same eufy security app on my iPhone so no need to install another app for this.
