Eufy 15C Max scratch under glass
We’ve had the 15C Max Robovac for a couple of months and it’s been great. Today I want to empty it and noticed that there were some scratches on the glass top. On closer inspection they are on the underside of the glass and it looks time the blue paint is delaminating. Has anyone else had this? It is quite difficult to take a photo of, but there is no damage to the top/outside of the unit.
Never seen.
I would say,thats not such a problem.
If the RoboVac is wotking perfectly, forget about.
May be it stuck somewhere and there was a kind or pressure, not damaging the plexi only the plastic under it.
That just looks like paint embedded in the top and can easily be wiped off with some alcohol. I had similar issue and upon closet inspection I found it just to be paint from a furniture piece it had gone undef
Yes thats a solution.
Some polish will do.:smiley:
That really is odd @abarkwith
For scratches to appear under the glass it must either have always been there or something mechanical has made contact with the glass :thinking:
It’s definitely under the glass and not paint on top. In both scratches the blue paint has come away and in one there is some metal that can be seen through the glass.
