Eufy 11s after vacuuming leaves dust everywhere
I use my eufy everyday and thoroughly clean the robovac after every use. Even on top of the machine is dusty… I don’t live on a dirt road. Please help!!
Have you really cleaned the filters on top of the dust container and the mesh there from both sides?
Than take a look after you have taken out the dust container if something sticks there at the “mouth” of the middle brush
Mine gets physically dusty too.
I have a friend with a different brand and hers does too.
I think it’s purely because its so close to the floor and has a shiny top.
Not sure of anything can be done @dawna1294
But as @Chiquinho mentions. Keep those filters nice and clean and thats about all you can do.
Strolling under wardrobes, will keep the top dusty and dont forget the
electrical charge of the Robot.
Yes I clean everything everyday after the vacuum finishes;charging magnets, roller brush , wheel and basically everything.
Thanks y’all
