Ethernet status
I just set up my EufyCam 2C system. Everything appears to work but my routher’s ethernet status light is yellow and, if all its well, should be green. What is causing the yellow light?
You should tell us more about the router 2,4 GHz or 5 GHz?
It is a dual band 2.4G and 5G. And the system works fine, so far, we are pleased about the quality of recordings and pictures, still the router light of the port used for Eufy Base is yellow.
@qui2 have you checked the link speed on your router? Depending on make, some routers show yellow when the link is running at 100mb instead of the maximum speed available (for most these days 1Gb)
Edit - just checked my Homebase and it is amber and running at 100mb on a 1Gb port.
The edit applies to me too. the Ethernet port (dual band 2.4G and 5G) is running at 100Mbs.
Thanks.
No worries, good to know things are fine :slightly_smiling_face:
