I am planning to buy a macbook air 2019 tomorrow and I just my anker vertical mouse today. Can I still use it? And how?
Ergonomic mouse to Macbook Air 2019
The mouse will work on MacBook but since the bluetooth reciever that comes with it is USB-A and MacBooks only have USB-C ports you’ll have to buy an USB-A to USB-C adapter or hub
Anker sells theirs for $9.99
Apple sells theirs for $19.00
You can probably find it cheaper somewhere else or you can buy a hub instead. They are more expensive but useful since they have USB-A to USB-C, hdmi, ethernet, etc.
Hopefully this helped Let me know if you are still confused
