Entry sensor gone offline
Hi there, and happy new year to all.
One of my entry sensor has gone offline, I checked and replaced the battery, and when putting the battery in the white light flashes for a while (Homebase pairing if I remember well), but then when I put the sensor in place and try open close the door, the light flashes red (offline) and the sensor is reported offline in the app.
Anyone else had that issue, anything I can try? or the sensor died?
Dont have any of these products, sorry.
But you should try a hard reset.
This often helps to get out of such issues.
