Easier Device Switching on Liberty 4 Pros (and others)
I switched to the Liberty 4 Pros from Galaxy Buds Pro 3s and have been really happy overall. The one bummer is that while multipoint is great for those using two devices, if you use three or more devices, there is no good way to switch around.
On my Galaxy Buds Pro 3s, anytime I wanted to switch (provided I’d previously paired with the device I’m switching to) I could just initiate a connection request (eg, just click or select the Buds from the BT menu) and they’d disconnect from whatever they were previously connected to, and connect to the desired device. Easy!
With the LP4s whether multipoint is turned on or off, if their connected to a device right now, and I initiate a connection request from a different (yet previously paired) device, they don’t switch. My only option is to disconnect (from the device or via the Soundcore app) and THEN initial the new connection request.
As someone who switches between at least three devices quite frequently, it really adds friction, and if the next Galaxy Buds works out better than the 3Ps did for me, I’d switch back for this feature. If not for that, I’d be happy sticking with the LP4s and presumably, future models.
