any idea where to get replacement ear tips. I need a set of small, not a set of assorted sizes
Ear tip replacement
Try Amazon
Hi @m.p.conner
Welcome to the community.
@ikari04warrior has offered the best advice although to add you will probably only find a multi sized pack (small medium and large)
It would be great if you post a link if you find something suitable and also what model of earbuds you have, that will help out others who need compatible replacements.
Hopefully see you around the forum from time to time.
