When my phone receives a notification there is no sound or vibration to alert me. Looked at all the notification phone settings and all are turned on. Suggestion?
Figured it out. Do not disturb setting on my phone.
I would suggest deleting and re-installing the app…is this iOS or Android?
This sounds like an issue with your phone or settings… not with eufy
Never mind I figured it out. It was a “do not disturb” setting on my phone.
It would be helpful to others if you could update your original post with the solution that you have found
That’s what I figured haha. Glad you got it figured out!
Nice to see these type of threads once in a while… I do it all the time.
