Does anyone know if Anker makes a Power Adapter for this Anker Product?
Amazon sells an Anker product used to connect external 3.5" or 2.5" HDDs to your PC via USB:
Description:
Anker USB 3.0 to SATA Portable Adapter, Supports UASP SATA I II III for 2.5 inch HDD and SSD
The description states it requires a power supply to work with some HDDs:
Please Note:
** With a separately purchased power adapter **
**(input: 100-240V, 50-60Hz output: 12V/2-3A), the adapter will read **
3.5-inch HDDs and SSDs.
However I can’t find a listing for an Anker Power adapter meeting this description.
I can find other manufacturer’s power supplies, but would prefer to stick w/ Anker.
Anybody know the answer?
Thanks
I was going to offer options, but if you search
Anker USB 3.0 to SATA Portable Adapter with 3ft Cable and Power Adapter for 2.5/3.5 inch HDD and SSD
This one has the ac adapter included for 11 bucks more. 11 dollars for an ac adapter of that power handling is about right.
